    Havent mastered this process so maybe someone can help.
    I can see how to upload and attach pics, Seems a bit long winded, but I can manage that, but then a bunch of pics appear after the post.
    But if I am writing a screed and want to include a pic within the text then what is the process.?
    That's a good question
    Did that work?
    Seemed to.. All I did was write the screed with a few line returns where I wanted the picture and then put the curser where I wanted the picture and hit the 'insert image' button.
    If you edit an existing post the pictures will appear wherever the "ATTACH=CONFIG]28256[/ATTACH" entries are placed (I've removed the leading and trailing [ ] brackets to make it show up as text for this example). You can move, copy, paste as much as you like.
    and it worked with a first image
    Second image though (treated in the same way) , ended up as an attachment instead
    What am I doing wrong??
    http://www.mycncuk.com/threads/13730...compound-table
    Not sure. Maybe it's the image format. Are they all JPEGs?
    Upload an image
    Write some blather. Upload another
    More blather.
    Seems to work for me. Each time I want to add apicture I'm hitting the insert image button, then using 'from computer', 'basic uploader', 'browse', selet an image then 'Upload file(s)'.
    That's funny! I added an image while editting to check the tab titles, deleted it and now it's turned into an attachment I can't get rid of.
    All were Jpegs
    Wonder if it has anything to do with windows version or maybe browser
    Will have another go later .
    Wonder if Admin might want to clean up my messy posts a bit
    I've just found that under 'settings' there's a list of attachments and I've managed to delete the unwanted one from above. Not sure how images in-line with the text and images stored as attachments can be moved around. Maybe somebody else will be able to enlighten us both.
    Kit
    What size are the files because if too large they won't upload. I get this all the time when In take pictures with my phone which takes Hd pics which give largee files size, so i just load them into paint and resize then save.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Will have a look at sizes Jazz. What is the limit?
    Quote Originally Posted by John11668 View Post
    Not sure if I'm honest but think it's about 2Mb
  1. Replies: 1
    Last Post: 23-02-2020, 11:44 PM
  2. Replies: 1
    Last Post: 22-07-2016, 02:15 PM
  3. Funny machining pics
    By oscar in forum Workshop & Equipment
    Last Post: 30-05-2013, 03:55 PM
  4. BUILD LOG: small mill for machining steel. Max spend £500 including computer
    By Andrew Wilding in forum DIY Mill Build Logs
    Last Post: 20-07-2012, 03:46 PM
  5. BUILD LOG: Few pics of my homemade CNC mill
    By wiatroda in forum DIY Router Build Logs
    Last Post: 18-02-2011, 09:43 PM
