I think most people would cut it without turning it over. You just need a long enough tool and depth increments suitable for your machine.
Kit
PS I don't know you well enough to bare with you but I will bear with anyone who is willing to learn!An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
18-06-2020 #2
So clamp from the top, cut in between the clamps, then move them around and cut the bits that were covered? This seems prone to error and it's what I want to avoid. Or do you mean cutting the perimeter last and trusting the newly-disconnected piece not to chip or go flying off?
Besides, I'll have to turn it over sooner or later as there will be designs on both the upper and lower face.
18-06-2020 #3
18-06-2020 #4
Depends on how you want to tackle it and remove stock.
If removing all the outer stock then buy your self some Mitee bite low profile clamps. These will clamp it so you can machine away most of the material, then turn it over reclamp on the edges and remove the remaining stock.
Or if you want a cheap dirty method then machine a pocket in some scrap just slightly smaller diameter than your circle so it's a tight fit and tap the cut part into the hole. Take light cuts on the remaining stock and you won't have any issues.
However, seen as your using a rectangular piece of stock then just do a profile pass and leave tabs to hold the part or very thin onion skin. Screw the parts down in the corners of the rectangle.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
18-06-2020 #5
18-06-2020 #6-use common sense, if you lack it, there is no software to help that.
19-06-2020 #7
The most stupid Newbie question ever!!
By mattscarlett in forum General DiscussionReplies: 7Last Post: 30-06-2016, 08:09 PM -
Newbie computer hardware question
By chris in forum Computer HardwareReplies: 4Last Post: 16-01-2014, 05:12 PM -
NEW MEMBER: Newbie - question on bit types
By Steven W in forum New Member IntroductionsReplies: 2Last Post: 16-05-2013, 12:06 PM -
newbie with a tool id question
By bigmatt-s2rst in forum Tool & Tooling TechnologyReplies: 2Last Post: 03-10-2011, 06:16 AM -
Newbie Question ...
By Wobblybootie in forum General DiscussionReplies: 1Last Post: 03-12-2009, 05:32 PM
