I know nothing.
I know even less about this machine.
But, I'm 95% convinced (just through deduction) that Mach and the machine can't work together. Nor do I think that you need Mach - the machine has it's own motion controller - Omicron 3000 which is what you've been using to home the machine, etc. You need to take a step back to look up the CAM chain - whatever you're using to generate the CAM - Vectric etc., would need a post-processor that supports the Omicron 3000. Then I'm guessing you'd take the post-processed output (typically G-Code) and somehow download this into the Omicron.
So, hit the old Google and search for instruction on the Omicron 3000 - I spent 5 minutes and found lots of posts from people asking the same questions as yourself.
If you was considering a Mach retrofit (or other machine controllers such as UCCNC) - then it is the Omicron that you'd swap out for the BoB/whatever and then Mach/UCCNC would interface to that directly. There's a bit of pneumatic magickry around the Z on that machine though - could be interesting.
18-07-2020 #2
NEW MEMBER: NEWBIE(ISH) with a RYE Quantum QM2515
By BEACHBLANKET in forum New Member IntroductionsReplies: 8Last Post: 18-07-2020, 01:22 AM -
BUILD LOG: belt drive to ballscrew drive changeover advice required
By marbles in forum DIY Router Build LogsReplies: 4Last Post: 14-02-2020, 02:14 AM -
Drive pulley size, Y drive redesign
By threedee in forum Belt Drive, Pulleys & TimingReplies: 7Last Post: 01-08-2019, 10:56 PM -
Bridgeport Romi EZ Path S - Axis Drive Fault
By Nemo1966 in forum Machine DiscussionReplies: 0Last Post: 12-02-2018, 01:13 PM -
fixed one fault, not i have a second
By terry1956 in forum CAD & CAM SoftwareReplies: 0Last Post: 17-02-2016, 08:34 PM
