Thread: eBay router
Yes I have one of those machines, ordered just before lock down, I would have liked to visit during the build process but this wasn't an option. Things like all the screw in the rails as mentioned elsewhere, I had to finish drill & tap some of these. Also the cables weren't through the frame tube.
Position of VFD is personal choice.
I've added a galvanized plate across both sides of the bed side to reduce side spill of chips, I've added a similar plate to the rear of the gantry, I'll be adding a 4th to the very rear soon too. I've also added some triangle braces on the Z axis top plate, long term I'll do these properly.
Part way through a vac bed installation as I cut thin sheet and will eventually replace the supplied MDF wasteboard/baseboard with steel.
25mm aluminium parts would be fine, it's all down to bit you use and hold down method.
It doesn't do slow at speeds 300-1100mm per minute it's very noisy. Over 1150mm per minute it's fine. Our current bits allow cutting of 1050 sheet at 1150mm-1300mm - with a nice clean cut requiring minimal cleanup. We're changing to a slightly higher grade on next tool order to increase cutting speeds further.
23-07-2020 #2
25-07-2020 #3
1300x 1300 router with vac bed on Ebay
By Clive S in forum General DiscussionReplies: 0Last Post: 30-01-2018, 03:57 PM -
ebay con
By macca in forum Marketplace DiscussionReplies: 20Last Post: 08-08-2014, 12:43 PM -
Ebay purchase of RECORD SCM 120 router
By GEOFFREY in forum Machine DiscussionReplies: 6Last Post: 06-07-2013, 06:07 PM -
Anyone ever bought a Router from China? (not ebay ones)
By sly666 in forum Marketplace DiscussionReplies: 4Last Post: 03-11-2012, 10:45 AM -
BUILD LOG: ebay score dwt cnc router
By j4son in forum DIY Router Build LogsReplies: 12Last Post: 13-02-2010, 04:11 PM
