31-07-2020 #9
Some applied cunning can reduce the total number of outputs needed if you are limited. My cheap Chinese BOB has a total of one! The cooling pump is on the same mains switch as my VFD and runs continuously which allows better post-job cooling in my opinion and so doesn't need a BOB output. The one output is used as the spindle start output but is also used to switch a mains relay which starts the dust extraction.
