    Quote Originally Posted by Nemo1966 View Post
    Thank you - I don't suppose you know anything about contactors do you?
    This one looks wired as if it is an AC coil (the 240v neutral loops back into the coil). Any idea what sort of ampage the coil will use on these? I have looked all over tinterweb and can find zero info.
    I was wanting to put a 1 amp fuse on it.
    thanks again
    Typically on an AC contactor of this size, you'll have a Pickup rating of around 70Va with a Holding Va of about 8-10. So on 230vac, you are looking in the 0.4a range at worst on start-up and far less when holding so your well in at 1A.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    Absolute gent - thank you very much
    Every time I am wrong - the World makes a little less sense.
    One last thing, if I may. The manual seems to be a bit ambiguous with regards to the 0 - 10v speed controller input.
    "Set speed Term 3: Potentiometer minimum or 0 to +10V, impedence 100K ohm filtered"
    So, Potentiomemrer or 0 - 10v, yep all good... impedence 100K filtered???
    The diagram shows:
    The reason I ask is that only 2 wires were connected originally (to 2 and 3). I'm guessing a 0 - 10v.
    I do not quite understand this sign in the picture:
    I am connecting to an MB3 breakout board with a 0 - 10v, page 20 on the link below for details
    http://www.cncroom.com/downloads/MB3...al%20E13R1.pdf
    Any help gratefully recieved
  1. VFD Wiring
    By Norman_A in forum General Electronics
    Last Post: 02-07-2020, 06:37 PM
  2. cnc wiring
    By crossleymarko in forum Gantry/Router Machines & Building
    Last Post: 09-04-2012, 09:35 PM
  3. help me for wiring
    Last Post: 28-11-2010, 01:20 PM
  4. Wiring Help
    By Toddy in forum Motor Drivers & Controllers
    Last Post: 23-11-2010, 01:48 PM
  5. wiring help
    By ste68blue in forum Stepper & Servo Motors
    Last Post: 29-07-2009, 10:23 AM
