    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    i have inserted the G code below as well
    It does not look like there is a file in the ZIP
    cpf's Avatar
    Lives in digbeth birmingham, United Kingdom. Last Activity: 15-01-2021 Has been a member for 4-5 years. Has a total post count of 12.
    1ft Christmas tree.zip
    Quote Originally Posted by cpf View Post
    I can't see anything wrong with the file apart from not having a G21 at the top
    T1M6
    G17 G21
    G0Z20.000
    G0X0.000Y0.000S22000M3
    G0X0.172 Y2.503 Z6.000
    As a workaround could you reduce the DXF file in Vcarve with scale .
    It is under "transform objects set size". and reduce it with the %
    cpf's Avatar
    T1M6
    G17 G21
    G0Z20.000
    Okay Great! We will give that ago and if it works use that until the new pendant arrives .We do have Mach 3 on a PC and are also thinking of just using that from now on if the pendants do break, and most people seem to have a PC linked up as it is much easier. Do you know if i would need anything new to connect my pc with Mach 3 on it to my rich auto circuit board. I'm thinking a new circuit board but unsure as to which one ?
    Many Thanks Bria
  1. CNC Programmers Needed in West Midlands
    By EncoreTechnical in forum Opportunities Available & Sought
    Last Post: 09-03-2012, 10:28 AM
  2. NEW MEMBER: Hi from West Midlands
    By wiatroda in forum New Member Introductions
    Last Post: 09-02-2011, 10:42 AM
  3. NEW MEMBER: Hi all from west midlands
    By phillip in forum New Member Introductions
    Last Post: 28-01-2011, 10:18 AM
  4. NEW MEMBER: Hello from West Midlands
    By range3rrr in forum New Member Introductions
    Last Post: 25-09-2010, 01:58 PM
  5. NEW MEMBER: Greetings from West Midlands
    By Steve Grafix in forum New Member Introductions
    Last Post: 23-08-2007, 01:33 PM
