Page 3 of 3 FirstFirst 123
  1. #21
    Lives in Plymouth, United Kingdom. Last Activity: 3 Hours Ago Has a total post count of 1,743. Received thanks 297 times, giving thanks to others 11 times.
    That's the one - couldn't remember the name. I've looked at it but never actually used it as my router did not have a suitable probe. For small pieces where height was critical (typically engraving) I've skimmed a spoil board but that can't cope with an uneven workpiece.
    Kitwn - good to see telepathy working at such a distance!
  2. #22
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 3 Weeks Ago Has been a member for 7-8 years. Has a total post count of 984. Received thanks 118 times, giving thanks to others 52 times.
    There's all sorts of crap hiding in my brain. Just needs a trigger to bring it out. And a little help from Google.
    Kit
  3. #23
    Quick status update.
    I've ordered a 20x12 vac table - that size suits the star mill fairly well. I was preferring the pressure foot solution, simply at the moment I use ground dowels to locate the board for 2-sided alignment, and don't fancy drilling the holes for the dowels in a vac table... but I'll figure something out. Discarded: DIY 3d-printed pressure foot - altogether too clumsy, and the £40 Chinese pressure foot (try finding one in the UK... everything is 3-4 week delivery - i.e. from China) - plus the thought of attaching the whole assembly without knocking the tip off the engraving bit scares me. That remains an option if the vac table doesn't work well enough (though I think it will).I reckon I'll need to add two edges to the vac table to align the board adequately. So, thanks to m_c for the recommendation (I've ordered from the links you kindly provided). Thanks also to the other suggestions - all valid in their own right.
    Now... anyone know any chemistry for bright copper plating an activated PCB substrate? (I'm about to throw myself at the mercy of an electroplating supplier but there's too much secret-blend-of-11-herbs-and-spices to lock you into their supply chain).
  1. MSC Clamp set offer
    By mekanik in forum Workshop & Equipment
    Last Post: 12-01-2015, 07:25 PM
  2. what's the name of this clamp and where to get it in the UK
    By dsc in forum Tool & Tooling Technology
    Last Post: 27-12-2014, 02:06 AM
  3. Vacuum pump for a large matrix bed cnc 5 by 10 foot
    By gavztheouch in forum General Electronics
    Last Post: 03-11-2013, 06:01 PM
  4. Changes a foot????
    By Swarfing in forum General Discussion
    Last Post: 29-06-2013, 10:44 PM
  5. Step clamp
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 02:39 AM
