Don’t get me wrong it worked and I could make 1 or 2 or sometimes 10 or more of the same component one after each other then for no apparent reason it would lock up and stop on a certain line of gcode
You could stop the gcode and star it from the point of failure or from the beginning then it would lock out on a different line of code
Restart mach3 which meant rehiring then lathe and run the same gcode and it would be ok for a number of runs or maybe fail on the first run
Totally random
I moved to linuxcnc and never had any such failures. Same pc same lathe and control electronics just linuxcnc instead of mach3
This caused me so much frustration over the years
Paul
01-02-2021 #2
You are both comparing apples with oranges.!!
Mach3 was and is known to be very flaky on the lathe side, for a Mill it's much more stable, but it still and always has done some weird shit for no apparent reason this is a known thing with mach3. Art used to try and nip these things in the bud ASAP but more often than not he fixed one thing and broke three more things, however since brian has taken over nothing got fixed and new hidden bugs have surfaced that will never be fixed. This is one of the reasons why I've stopped using mach3 and moved to UCCNC, it knocks the spots off Mach3 and is rock-solid stable.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
05-02-2021 #3
SOLD: Hobbymat MD65 mini lathe and BF65 mini mill
By Boyan Silyavski in forum Items For SaleReplies: 3Last Post: 03-11-2018, 12:45 PM -
equivalent of HAAS mini mill 2
By pnub93 in forum Machine DiscussionReplies: 16Last Post: 10-02-2018, 02:19 PM -
Mini 5 axis cnc mill
By andy_con in forum Machine DiscussionReplies: 1Last Post: 16-12-2015, 09:46 PM -
eBay: SX2 Mini-Mill - Complete Setup.
By grunt-will in forum Items On eBay UKReplies: 2Last Post: 30-01-2014, 08:28 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM
