24-06-2021 #2
This is for my micro lathe experimental project and will be used as X axis. It's an experiment only, but movement is short since the chuck is only 100mm, so I figure 80mm is enough. I will never need to make anything with 160mm diameter anyway. Initially it won't have any steppers on the axes, so no need for limit switch. My CNC Z has limit switches but only the upper one is ever triggered. That is different, there I have 160mm Z clearance and 140mm movement, so it is much larger and wider than this is going to be.
Xzero Raptor CNC build - linear rail and ballscrew selection
By Mattia in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 27-08-2021, 01:34 PM -
2m+ travel lengths with a ballscrew, using linear rail to support the ballnut
By Desertboy in forum Rails, Guideways & BearingsReplies: 9Last Post: 04-02-2018, 06:50 PM -
3 axis ballscrew and rail kits on ebay
By Richard in forum Classified Ads, Buy, Sell & SwapReplies: 9Last Post: 18-05-2017, 02:06 PM -
NEW MEMBER: Hi,Friend,I'm a B2C seller from China for ballscrew,linear guide,linear shaft etc.
By yvesleeok in forum New Member IntroductionsReplies: 11Last Post: 10-08-2013, 11:15 AM -
Linear rail and ballscrew dimensioning for R/C router
By CarlNicholasCarlsson in forum Linear & Rotary MotionReplies: 0Last Post: 24-03-2013, 06:52 PM
