Page 5 of 9 FirstFirst ... 34567 ... LastLast
  1. #41
    Quote Originally Posted by Amera View Post
    _CaThe 1605 nut sleeve I have is 40x40x52mm, that is true, but you need to use it right, which is the screw holes up, where it is 52mm wide. That is the minimum space you need to have between carriages, unless you come up with a different solution.
    Thanks A Camera, yes I appreciate that, i know they don't fit - it was the 40mm size that i wanted, as that will allow alignment of the linear rails as they are exactly 40mm apart
    I don't claim to be an expert, but a friend asked me for advice because he needed to create this shape but could not get it right, so I made this video to show him one possible way to do it. In FreeCAD some things can be done in many ways, there is no right or wrong, but he needed a quick help, so I showed him my quick way for this simple thing.
    Will watch your video later this evening - thanks for the link
    WoodKnot
    Carpe Diem
  2. #42
    Hello all -
    So I was initially thinking of using my Dewalt 1/4" router for my spindle -
    But thinking of other options, what would you recommend?
    Do i need to go water cooled or air cooled? Was also thinking about the noise element as well.
    I don't want to purchase the spindle mount until i know which motor I am going to use
    Thanks in advance
    WoodKnot
    Carpe Diem
  3. #43
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Generic option is a 2.2kw water cooled spindle, which eBay usually has abundant sources.
    Bit fancier is some of the spindles Jazz is selling, but they will be more expensive.
    Water-cooled is the quietest option, but if you've already got a decent router, you can always use that to begin with.
  4. #44
    Good evening Jazz, images as requested.
    Just about to take my daughter on her driving lesson
    Attachment 30182Attachment 30183
    Attachment 30184
    Sorry, I thought this post went out much earlier
    WoodKnot
    Carpe Diem
  5. #45
    Let's try again
    WoodKnot
    Carpe Diem
  6. #46
    And finally JAZZCNC, the base is sat on 2040 profile
    Thanks again
    WoodKnot
    Carpe Diem
  7. #47
    I also have the generic 2.2Kw Wc spindles with Huanyang VFD ..
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  8. #48
    Quote Originally Posted by WoodKnot View Post
    Thanks again
    WoodKnot
    Ok thanks, leave it with me I'll look at it ASAP, I'm going to get very busy shortly as parts for the second batch of routers are arriving any day soon , then it will be all hands on deck getting them built so time will be in short supply.
  9. #49
    OK, never used a water cooled unit? So presume that they come with the pump unit part?
    I have also noted that some need an inverter as well? Why do they need inverters?
    This seems to be pushing up the cost considerably.
    Do i really need this for just routing out a few wooden signs?
    WoodKnot
    Carpe Diem
  10. #50
    Main reason for using water cooled Spindle is the noise or lack thereof, you need an inverter as they they are three phase, you need to provide a small tank and a pump. you will be fine with an ordinary router but again it's the noise, this would get very old if you are doing a long run on the machine, you need also to be looking at a dust shoe to fit whatever device you wish to use.
    Good luck
    Regards
    Mike
  1. OpenBuilds C-Beam machine
    By Lodds in forum Gantry/Router Machines & Building
    Last Post: 25-10-2020, 04:39 PM
  2. Will the openbuilds ox cut aluminium?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 19-05-2019, 07:12 PM
  3. Turret style cylindrical cnc grinder build
    By SGG70 in forum Other Machines & Building
    Last Post: 19-12-2018, 02:00 AM
  4. SOLD: Openbuilds 3D CNC Router for sale
    By Leadhead in forum Items For Sale
    Last Post: 15-12-2018, 09:30 AM
  5. Anyone have info on OX CNC made by Probiotix openbuilds
    By totally useless in forum OpenBuilds OX CNC Machine
    Last Post: 16-06-2015, 02:16 PM
