Thread: Looks impressive for the money ?
17-07-2021 #13
Hmmm, that module you linked converts (or claims to convert) a PWM signal into an analogue signal. All three input methods on the laser control board are TTL/PWM. If your intent is to use that board with the laser to control power, I don't understand how the laser is intended to take an analogue voltage.
Edit:
Consider also the Arduino PWM outputs, if using the built in libraries (counter driven PWM) operate around 500Hz.. That module claims 1kHz -> 3kHz operation. Just a health-warning on compatibility.
NEW MEMBER: New member help me spend my money
By Jiroma in forum New Member IntroductionsReplies: 7Last Post: 17-08-2018, 10:40 PM -
RFQ: Can someone make this for me? For money?
By richardmayo in forum Projects, Jobs & RequestsReplies: 1Last Post: 16-11-2013, 02:00 AM -
Need some money making project ideas
By Fivetide in forum Marketplace DiscussionReplies: 10Last Post: 23-11-2012, 09:50 AM -
Which part of *your* build leaked the most money?
By CNCBlug in forum General DiscussionReplies: 3Last Post: 08-03-2010, 07:59 PM -
Easy money
By HankMcSpank in forum General DiscussionReplies: 2Last Post: 06-07-2009, 12:39 PM
