No, thats peak current. In general the 2 phases are never both powered fully all the time so a sort averaging occurs and anecdotally (although Mariss of Gecko fame did show the maths once) its 66%!
Its usual to quote feed speeds in mm/min for milling - so 2520mm/min is good, 1500mm/min isnt bad tho
Strange... if you haven't already, try swapping driver channels to validate its not a driver issue, then motors (assuming they are the same) to validate its not a motor issue
26-05-2010 #2
Thanks for the clarification. Do you by any chance have a link to the 'maths' behind this? I'd be interested to see..
(I quoted the feeds in mm/s since personally I think it's better to work with smaller numbers and easier to visualize, but I'll endeavor to stick with the convention from now on)
I've only wired up one driver so far, so that can't be the issue. I'll try swapping the motors though. All the motors are the 3N-M ones.
The handle for the Y axis (before I removed it) did seem a little harder to turn than the X-axis so I may try loosening the nut. I tightened it to reduce the backlash. Annoyingly to get to the nut you have to take the bed off the machine and all sorts...takes ages :(
Matching Drivers with Steppers
By hoppo in forum Motor Drivers & ControllersReplies: 4Last Post: 21-11-2012, 01:19 PM -
Any one used drivers and steppers from CNC4you
By sebring115 in forum Motor Drivers & ControllersReplies: 14Last Post: 30-11-2011, 11:32 PM -
Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
By Mad Professor in forum Stepper & Servo MotorsReplies: 12Last Post: 01-09-2011, 10:09 AM -
Has anyone used these steppers or drivers?
By Jonathan in forum Stepper & Servo MotorsReplies: 2Last Post: 24-03-2011, 02:24 PM -
Steppers and drivers
By Davidh in forum Motor Drivers & ControllersReplies: 3Last Post: 12-06-2009, 05:59 PM
