Thanks Doddy. Yes, I forgot to mention in my response to routerdriver, the driveway is flat right up to the garage door, so I'm hopeful that pallet trucks and skates will get me in and out again (at a later date) safely.
21-01-2022 #2
We deliver machines this size and larger using the pallet truck and skate method, in fact, delivered a 10 x 5 yesterday using this method across a rough Chicken shed floor.
one skate on each corner at one end and pallet truck at the other.
Just make sure that the skates don't sit metal to metal as the machine will slide off if they stick or jam, 2 ton doesn't exactly stop instantly when it's rolling and will try to slide off the skates in a blink of an eye. Put some wood or rubber between the frame and skate.
Also, it's a good idea if possible to connect the skates with a bar so they both travel in the same direction as they have a tendency to follow the floor and can easily go in opposite directions, or have one person on each skate making sure they steer them in the same direction, if not they will jam and potential for falling off skates.
A Trolley jack also works in place of a pallet truck.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
21-01-2022 #3
Thanks @JAAZZCNC, great to hear this is how you deliver and move machines too, very comforting. Thanks for the tips about the weight shifting, good to know, cheers.
22-01-2022 #4
As a temporary measure just for moving you could always just bolt-on 6" or 8" castors like these on each corner. We use these on frames which we built for delivering machines where we have to move them down garden paths and thru narrow doorways with the machines on their sides and they easily handle rough terrain and roll nice.
Just for rolling out of a workshop, they will work a treat and not silly expensive. Also, they don't mark painted floors being rubber wheels.
https://www.screwfix.com/p/industria...or-200mm/770kh-use common sense, if you lack it, there is no software to help that.
Piranha PJCM 1325 CNC Router
By Anthony Cutts in forum General DiscussionReplies: 1Last Post: 22-07-2024, 06:41 PM -
3 important Tips for Cutting Aluminum with your CNC Router
By LeonBlack in forum Tool & Tooling TechnologyReplies: 4Last Post: 20-11-2019, 08:53 AM -
BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
By GeorgeW21 in forum DIY Router Build LogsReplies: 14Last Post: 20-01-2019, 09:33 AM -
stepmores cnc router 1325
By voyager1972 in forum Chinese MachinesReplies: 1Last Post: 28-05-2017, 04:30 PM -
2008 EM 1325 CNC router
By jegg in forum Chinese MachinesReplies: 2Last Post: 28-01-2016, 11:19 PM
