Thread: 1 signal two stepper drives
Ok that will be why it can't Slave and this alone is sign that it's not a very good controller, expect issues along the way from other things.!
The current I'm talking about has nothing to do with the current required to power the drives and motors so PSU size doesn't come into it.
Without getting too deep or technical I am talking about the current Step & Dir Inputs which are going to draw from the controllers Outputs. Each Output will have a max amount of current it can supply which will be in the Milliamp range and the drives Inputs will require a certain amount of current to operate, again in the milliamp range, which they draw from the Outputs.
So, for instance, let's say your controller's Output can provide 15ma and the drive's input requires 7ma to operate so when operating a single drive there is no problem because you have plenty of spare capacity. However, controlling 2 drives then you do have a problem because each drive will pull 7ma requiring 14ma total but the output can only provide 15ma which doesn't leave any spare capacity and you could get issues from signal loss and lost steps, etc.
If the inputs pull more than the Outputs can provide then you could damage the controller and you will definitely have a signal loss at best if they work at all.
So to know if this will work for you then you first need to know the spec of the controller's Outputs and the spec of the inputs of the drive.
If not then you could easily run into trouble with crazy shit happening or blow the controllers Outputs.
Now because I'm guessing it's a cheap controller because its USB and doesn't slave and the fact the drives will probably be cheap drives to match then there is a good chance you will have the worst of both worlds where the Outputs are low current and drives inputs will require a high current. This is common of cheaper components.
In all honesty, USB is shite for CNC as it's flaky in power terms and easily affected with electrical noise, best avoided if possible.
Yes you can and some people just crash the machine into hard stops to square up but why would you when a proper controller will and should square it up for you in nice controlled why without you ever having to think about it.?-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
18-02-2022 #2
Looks like stepper output = 13ma. Inputs = 7ma. General purpose OC outputs = 500ma.
Not worth the bother tbf.
http://leafboy77.com/?page_id=25/
The 5 axis version of AKZ250V3 shows slave support:
https://www.aliexpress.com/item/1005...rch-mainSearch
http://leafboy77.com/?page_id=354
The EDG381 supports slave and is ethernet:
https://www.aliexpress.com/item/4000...rch-mainSearch
http://leafboy77.com/?page_id=271/
According to this the Druffel STB4100 usb supports a slave.
https://drufelcnc.com/doc/DrufelCNC_STB4100_manual.pdf
I see these on many budget routers:
https://www.youtube.com/watch?v=Lt6e6WI_GaE
https://www.youtube.com/watch?v=107CmKN2Md0Last edited by dazp1976; 18-02-2022 at 03:25 AM.
eBay: Stepper Motor Controller PWM Pulse Signal Generator Speed Regulator Board £6
By Lee Roberts in forum Items On eBay UKReplies: 7Last Post: 15-07-2018, 08:41 PM -
Stepper motor Pulse Signal Generator module
By Tom J in forum Motor Drivers & ControllersReplies: 8Last Post: 12-01-2016, 11:47 AM -
help sizing toroidal PSU to stepper/drives
By paulus.v in forum General ElectronicsReplies: 13Last Post: 28-01-2014, 06:40 PM -
Stepper Drives
By GTJim in forum Marketplace DiscussionReplies: 4Last Post: 05-04-2013, 12:05 PM -
Nema 34 Stepper Drives,
By drumsticksplinter in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 03-04-2013, 04:20 PM
