Is that some sort of IGUS bearing (sleeve) I see? It may be a replacement wear part or you my be able to find a IGUS bearing to fit.
Moving the slide without the ball screws should tell you quite a bit.
Gut feeling, with those steppers it's not the slides!
Sent from my SM-A715F using Tapatalk
26-04-2022 #2
26-04-2022 #3
axis alignment
By mkultra in forum Boxford LathesReplies: 0Last Post: 12-11-2021, 12:47 PM -
SH-350 Mirror alignment
By Wolfster in forum Laser Machines & BuildingReplies: 16Last Post: 30-03-2016, 03:47 PM -
Boxford TCL 160 tool alignment
By Saracen in forum Boxford LathesReplies: 2Last Post: 05-11-2014, 10:28 PM -
Lubricant for router cutter?
By Richie in forum Tool & Tooling TechnologyReplies: 7Last Post: 28-04-2012, 12:26 AM -
Mini Lathe alignment
By pequod in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 29-06-2009, 06:40 PM
