and the diagram in the manual is shown as if you are viewing from the rear, not the front which is where I think you are possible getting confused.?
Ah yes I now see what you are saying, I have a cable already I wanted to know the pin numbering from the FRONT of the cable connector. I didn't realise that they looked different from the back.
The cables I have are the 4th pic in my original post. So I wanted to cut off the NON-Servo connector (36 pin serial) and trace back the signal with a multimeter and re-use them.
Looking from the back (like you say) then it does match what I thought on the servo 1 - 18 down the left side and 19 to 38 down the right side. Which will match the from of the FRONT of the servo.
thank you very much - sorry for not clicking sooner
