    Here is some video on cutting trials on aluminium & steel (I had never intended to cut steel, but it seems to do OK - I still think that the spindle is the weakest link).
    I would probably use less aggressive settings for any real machining.
    Quote Originally Posted by Misterg View Post
    I still think that the spindle is the weakest link. I would probably use less aggressive settings for any real machining.
    Yes your absolutely correct re the spindle Andy, do you plan to upgrade it? If so I can recommend Fred over at BST Automation for a decent 2.2kw water cooled spindle etc. Nice mod's to the spindle by the way :)
    Yea until/if then quite conservative feeds and speeds will be required with that spindle, you've built a decent machine that is capable of allot more with a better spindle...we all start somewhere though right...will go watch the video now...
  3. The Following User Says Thank You to Lee Roberts For This Useful Post:
  1. Diy CNC mill-router-thing in my attic
    By Pencilfish in forum Workshop & Equipment
    Last Post: 29-11-2021, 06:18 PM
  2. Funny forum thing.....:disillusionment:
    By Voicecoil in forum General Discussion
    Last Post: 07-04-2021, 06:47 PM
  3. Replies: 11
    Last Post: 26-08-2020, 09:04 PM
  4. Trying to get this thing to work
    By GeneO in forum Machine Discussion
    Last Post: 21-01-2020, 09:29 PM
  5. Bought a laser, now there's a thing
    By Robin Hewitt in forum Laser Machines & Building
    Last Post: 25-02-2013, 07:20 AM
