    My Kress spindle has started fluctuating speeds. The sound of the blade goes up and down occasionally. (doing it more and more)
    Is this a brush issue with in the unit? or is it replacement time?
    I'm not sure which model it is, but its in use a lot of the time. (its manual speed control, not controlled by Mach3)
    Quote Originally Posted by Millatime16 View Post
    I would suggest checking the brushes first, also take a look at the commutator to check for wear.
  3. The Following User Says Thank You to Voicecoil For This Useful Post:
    Thank you.
    I bought new brushes and installed them (the old ones were only a 3rd of length left).
    Sounds different and wavers a bit on start up.
    Do they need a bedding in period?
    I guess if it still plays up, its time for a new spindle. Seems the replacement is an AMB 800 FME-Q only available fir Germany.
    They seem to have a hard wired lead though. Mine has a connected that goes back to the CNC brain (for stop start). It doesn;t control blade rotation speed though.
  5. #4
    Thank you.
    They can do in order to make full contact with the commutator: the shape of the end of the brush doesn't always match it exactly particularly if old.
  1. WANTED: Kress spindle
    By Leadhead in forum Items Wanted
    Last Post: 14-09-2017, 02:08 PM
  2. GRBL milling stopping randomly
    By Datulab in forum General Electronics
    Last Post: 15-01-2017, 08:52 PM
  3. Kress Spindle upgrade to a 2kw
    By Metal pecker in forum Kress Milling Motors
    Last Post: 05-05-2014, 12:22 PM
  4. eBay: Kress 1050 FME-1 Spindle
    By viz in forum Items On eBay UK
    Last Post: 21-08-2013, 04:04 PM
  5. Kress Spindle Holder
    By GTJim in forum Kress Milling Motors
    Last Post: 25-05-2009, 07:02 PM
