Thread: Belt drive and pulley sizes
Thanks guys.
@ irving2008
It will be an all MDF machine. Do you think there will be deflection in that section? its only 200mm x 150mm square rom top to the V bearing line. But I'll put that in mind and incorporate a provision for some kind of reinforcement in that section.
@ John S
There will be support bearings at either sides of the big pulley and another 2 at the ends of the shaft. What I has me worried about is the Y lateral support (where the X motor's located). Do you think it will still provide rigidity as it is now divided into two to make room for the belt tot pass thru?
Again guys thank you very much.
JOrdanLast edited by j2sip; 20-06-2010 at 01:06 AM.
20-06-2010 #2
Timing Pulley/Belt sizing software
By m_c in forum Computer SoftwareReplies: 4Last Post: 12-04-2014, 03:33 PM -
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
pulley center distance vs. belt tension
By dsc in forum Belt Drive, Pulleys & TimingReplies: 5Last Post: 13-01-2014, 10:48 PM -
Where can i find belt and pulley for a spindle?
By JW1977 in forum Marketplace DiscussionReplies: 5Last Post: 12-11-2013, 08:03 PM -
AC Motor upgrade - pulley sizes
By birchy in forum Linear & Rotary MotionReplies: 7Last Post: 21-06-2013, 10:49 PM
