Page 1 of 3 123 LastLast
    I've been wanting to do this project for a while. I wondered if it would be possible to build a spindle monitor to check if it has stalled out and then e-stop. Hopefully this would stop it breaking end mills. Sounds easy in principle . . .
  2. The Following User Says Thank You to routercnc For This Useful Post:
  3. #2
    I would exxpect the VFD to have a motor stall function in it's parameters, the ABB one I use certainly has although I have not tested it in practice.
    Maybe but I've not found it in the 'documentation'. Would simplify things if it did.
  5. #4
    Episode 2, just making it better all round . . .
  6. #5
    These inverter parameters look interesting;
    PD118, PD119, PD120, PD121, PD122, PD123, PD124, PD125
  7. #6
    Reading them now. Looks interesting! Worth experimenting with to see if it really can detect a stall through current monitoring and then trip the onboard relay (although I think that is omitted on my model, although I might be mixing it up with the inverter inspection I did for the drill press project)
    External current monitoring did not seem to show much but maybe internally it is reading a different part of the circuit.
    Might turn out to be the biggest waste of time project (except for the fun and learning)
  8. #7
    I decided to look into the inverter parameters . . .
  9. #8
    Prototype PCB!
  10. #9
    More developments, some hardware but mostly software including storing user values in non-volatile memory. Also a look ahead to the next PCB revision . . .
  11. #10
    New PCB boards to split the LCD display and the processor. Went smoothly apart from the bits that didn't.
There are currently 49 users browsing this thread. (0 members and 49 guests)
  1. X Axis Stall
    By AndyW in forum Machine Discussion
    Last Post: 09-10-2021, 09:33 PM
  2. MACH3 hitting soft limits causes X axis to stall
    By STK2008 in forum Milling Machines, Builds & Conversions
    Last Post: 28-09-2020, 03:44 PM
  3. stepper motor stall?
    By mancave newby in forum Machine Discussion
    Last Post: 22-06-2018, 06:59 PM
  4. em806 Senssorless Stall Protection fault
    By charlieuk in forum Motor Drivers & Controllers
    Last Post: 15-11-2017, 11:36 PM
  5. Digital Drivers and Stall Detection
    By Washout in forum Motor Drivers & Controllers
    Last Post: 10-12-2013, 05:02 PM
