23-06-2010 #7
Current Activity: Viewing Cheap milling machine spindle - BT30-ER20, air powered draw bar + Tear Down!
Hi 8iggles,
Knew I'd seen it somewhere, try this:
http://www.mycncuk.com/forums/showth...spindle-design
I just skim read it again and it might be just right for you given your mild loads. Based on a brushless motor intended for model aircraft, cars etc. These are all over ebay (Chinese).
Just off topic briefly, since you asked, the Avatar is my own design - called Precision3. A 1.9m span Patternship running from a 10s Lipo (36v), 2KWatt brushless motor, 100A Opto SC. 5.2kg all up weight, 2 years of design, CAD, hand cut out (pre-CNC m/c!), build, cover and fly. Maiden flight about 1 month ago. Wonderful flier with no downthrust, side thrust or incidence changes required. I'll not be at the green acres - bathroom project (but Cosford LMA is on!). OK, back to the spindle . . .
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
type of shafting for round linear bearings
By quickcut in forum Rails, Guideways & BearingsReplies: 2Last Post: 11-08-2013, 10:17 PM -
FOR SALE: rails, screws, bearings and spindle
By wilfy in forum Items For SaleReplies: 16Last Post: 10-04-2013, 01:50 AM -
spindle bearings overheating
By Andrew Wilding in forum Spindles & Drive MotorsReplies: 9Last Post: 15-05-2011, 01:21 PM -
FOR SALE: Elte type spindle 0.55kW 12000rpm 220AC 3-phase
By Vladimir_MD in forum Items For SaleReplies: 3Last Post: 16-05-2010, 06:48 PM
