  1. #21
    Daz's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 11-06-2026 Has been a member for 1-2 years. Has a total post count of 17. Received thanks 4 times, giving thanks to others 0 times.
    I have done some more digging and since it is a DC motor, you will have completely different torque curve, with some significant torque available from the start. Theoretically many times higher to what I can get on my 2.2kw spindle at very low RPM, assuming your spindle DC power supply can handle it, it might actually work!
    You would need to sort out the manual speed control and the reverse operation, but other than that, it should work.
  2. #22
    Thanks for the extra information Daz. If the motor could generate the torque it would need a very different controller, the current one is KBE thermistor type. Something that would generate stall current at low volts would be needed, and anyway as it's a PM motor it might be field limited. Also the height would severely restrict me and my table is only 125mm wide! Shame it's a very nice concept.
  3. #23
    That's as cool as a Hippy Penguin's Jesus Sandals!
  4. #24
    Quote Originally Posted by JohnHaine View Post
    The whole point of an Impact Driver Mechanism is that it isn't reliant on motor torque, it releases the drive in response to pre-settable torque demand, allowing the spindle to accelerate, it then uses spindle system angular momentum against a braking mass to apply the required torque, repeatedly.
  5. The Following User Says Thank You to magicniner For This Useful Post:
  6. #25
    Very cool!
    Cant wait to see your first cassette of tooling in play and in production
    Daz's Avatar
    Very cool!
    Here is my first job using the ATC modules. The cover needs some improvements to keep the collets clean.
    https://youtu.be/FH3Ue6h8MHE?si=oE4Sxmk5fvD7b8i3
  8. The Following User Says Thank You to Daz For This Useful Post:
  9. #27
    That is Totally Ace!
  10. #28
    That's true when tightening but loosening is a different matter as the spindle will be stationary.
  11. #29
    Daz's Avatar
    It is the same for tightening and loosening. The operating principle doesn't change. The average torque required to spin the module is low, but the impact torque resulting from the hammer hitting the anvil is high. The impact happens two times every full revolution. The impact torque depends mostly on the spindle RPM.
    The main difference between tightening and loosening is that for loosening, the spindle needs to overcome the initial module resistance from the standstill. The resistance comes from the need to overcome the hammer return sprint in order to depres the hammer. Once the hammer is depressed, the anvil (top of the module) can slide over it and make the rotation.
  12. #30
    Aha! Right, I didn't spot that in the video.
  1. Which laser module?
    By grantx in forum Laser Machines & Building
    Last Post: 12-07-2021, 12:22 PM
  2. FOR SALE: CS-Lab IPA with MPG Module / Handwheel etc - £450.
    By Chaz in forum Items For Sale
    Last Post: 13-12-2019, 11:13 AM
  3. WANTED: stepper driver module
    By tinshak in forum Items Wanted
    Last Post: 16-01-2013, 09:31 AM
  4. FOR SALE: ER20 DIY Spindle Parts
    By Mad Professor in forum Items For Sale
    Last Post: 03-11-2012, 06:51 PM
  5. ER20 Collets
    By audioandy in forum Tool & Tooling Technology
    Last Post: 05-08-2009, 10:15 PM
