I think we all know what is possible, especially with 4 and 5 axis machines
but I still say WOW and am impressed
let me know if you've seen a vid which demonstrates CNCs capabilities as the bigger the library to show the other half the great the chance of convincing
PS. I've got 2x 1m and 2x 85cm THKs rails with 8 blocks, a 1m and 85cm THK screw, and a 50cm screw + rails n bearings, 3x Gecko 203s she doens't know about.
I just need to commit to a design and ask for your kind feedback.
building in 3weeks - finished in 6 weeks or much less HOPEFULLY
PPS anyone good at welding 90* corners with box steel within the M25 and need some pocket money?
PPPS Why are RSJs not used where long box section flexes/twists and 15-20mm plate is too expensive?
16-07-2010 #2
Hi Williamturner1,
RSJs are actually no better in bending than a similar sized box section, are are also very much worse in torsion. Plate, even thick plate, can also be poor because you need material away from the neutral axis for stiffness i.e. wide hollow sections.
See the 'gantry stiffness' spreadsheet in post#2:
http://www.mycncuk.com/forums/showth...ign-principles-.-.-.
If you have a box section which is bending or twisting too much you either to add additional supports, or need to increase the section size. Sorry, RSJs are not a panacea.
As for your new machine, sounds like you a have a nice list of bits - but naughty you for hiding them :whistling: ! Start up a new post with some sketches, scanned drawings, whatever you have, and we'll make some comments. It's worth adding what you want the machine to do.
17-07-2010 #3
Wicked Thread you linked to and epic spreadsheet!!
I'm considering 90 x 150mm RSJ over 120 x 80mm 4mm Box; partly as I have 4 meters of RSJ and no box but mainly as my brain tells me 90x150 RSJ wouldn't flex like Box Section would ... but the spreadsheet says otherwise
RSJ Data for the spreadsheet, 2nd entry in the table = 90x150mm : http://www.steel-beam.co.uk/universal-steel-beams.php
I've got 9 sketches on the back paper out the office recycling bin ... I just need a bit more time to filter the embarrassing mistakes before I post a few up and ask you to say which will be the most bendy and the least!
Thank you for the quick feedback. I can't wait for more and to start building!!
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM
