Thread: The illusive Boxford 260vmc
31-07-2010 #21
i2i has kindly pointed something out to me. The Steppers & Stepper drivers are usable however i have to devise or find a way to interface the 12v drivers with the 5v parallel port, has anybody here addressed this problem? the stepper drivers are : - "PKS-DIGIPLAN SD3's" ive found some Free manuals for the drivers on the DENFORD Site which i am at this moment digesting (or trying )
31-07-2010 #22
31-07-2010 #23
Wellifyou intend to service it,Rick?
Just video closely what you do to remove/disassemble and then watch the video onhow you removed it to begin with....mind you you will have to play the vid backwards on assembly:heehee:
31-07-2010 #24
I have managed to find a wiring diagram named digiplan using two BC547's and a couple of 3k3 resistors it does seem to be a very simple circuit (but then they all are if they work!) but i can see from the diagram what is going on and i must say i2i is a very help full chap.. did you have an alternative to the digiplan interface ?
31-07-2010 #25
31-07-2010 #26
01-08-2010 #27
01-08-2010 #28
01-08-2010 #29
01-08-2010 #30
Ok here is a look at the machine before i picked it up.
And here is a picture of the breakout and control board. (ooooo that looks complicated)
Incidently this board has a date on the back of 23/1/95 so I suspect is an upgrade or replacement but without any pictures or the original board/machine electrics I cant tell what mods have been made to this machine.
If you have any thoughts or knowledge on the subject please pipe in!Last edited by Ricardoco; 01-08-2010 at 11:17 PM. Reason: Couldnt stand to look at my bad spelling any longer
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
