Thread: He's added a fourth axis
01-08-2010 #23
I've done it pretty much as per the video to be honest i.e. an angular contact bearing behind the chuck with a thrust bearing the other side of the plate and preloaded them, a simple bearing holds the other end of the shaft. Works really well for router use and I suppose it would work for light engraving on Aluminium but I'd never try machining, I'd convert a rotary table for that (Mr Kip was kind enough to donate a stepper adaptor for such use).
I'll tell you what was REALLY nice about this project. The fact I designed the plates and cut them on my macine and all the bits, bearings, stepper etc. just fit first time, no filing, no drilling larger holes because one was .25 of a mil out because the dot punch slipped, everything just fit and lined up. I know it SHOULD do that anyway but I still find it all amazing and it was worth doing just for that glow you feel when it all goes to plan. My mate at work Kenny has been doing CNC lathe for many years, most at RR, and he says he still gets the same kick when the bits all just slot together first time every time. Wonder if others do :)Nothing is foolproof......to a sufficiently talented fool!
DeskProto 3D cam software, forum support added!
By Lee Roberts in forum DeskProtoReplies: 0Last Post: 27-01-2014, 03:21 PM -
Fourth Axis... Thoughts?
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 08-07-2013, 08:24 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
