Page 9 of 35 FirstFirst ... 789101119 ... LastLast
  1. #81
    View from below Driver rack ready for Logic voltage mods.
    New tracks added ready for drilling and component additions.
    Solder side view with Components added and soldered
    Component side view
    All done, and ready for fitting back in machine...(maybe)
    Rick
  2. #82
    Quote Originally Posted by GeorgeD View Post
    Or a piece of foil and one of those ebay £25 point and shoot auto reader counters.
    Thanks George, I did consider going down that road and I may even buy one as they are a very reasonable price and usefull for other things, but i wanted to encorperate it into the machine nice and neatly, which as ugly as it may be the Trexon fitted the bill. Or even something similar I could get my hands on without waiting for eternity, but it seems that this type of circuit is not available off the shelf in the UK which im gutted about.
    I have so little time in my day as it is, being a 12hr night shift worker, the only real time I can spare is sleep time, but it seems I will have to go down the Microcontroller road, as nobody on here at least can suggest any other alternative off the shelf solution to the Trexon .....:(
    Rick
  3. Quote Originally Posted by Ricardoco View Post
    ...All done, and ready for fitting back in machine...(maybe)
    Rick
    neat way of adding the level shifters... looking good...
  4. #84
  5. #85
    Think outside the box,or in this case inside:heehee:
    Buy one, position the foil somewhere on the spindle,strip down the tachomete handheld unit,unsolder the the sensor and put/mount the digital readout in the front of the case n the boxford,solder some wires to the sensor and resolder the wires from the sensor to the digital readout unit.
  6. Quote Originally Posted by GeorgeD View Post
    you missed two vital points George... firstly its not a sensor but a laser reflectometer which is only rated for pulsed usage and secondly, they are not continuous reading but 'read-on-demand' therefore need a push-to-read button ... as a speed readout its not that useful....
  7. Thats what I had in mind, but using a parallel interfaced display.. more common to find, cheaper to buy and easier to program.. for the added complexity of 5 more wires...
  8. #88
    Take a look at this.
    www.e3b6a5y.com/365/WiringDiagrams/365um6150rpfTACHO.PDF
    It seems to fit the bill?????
  9. Quote Originally Posted by Ricardoco View Post
    except it cant deal with the 50:1 reduction needed...
    except it can't deal with the 50:1 reduction needed
  10. #90
    Ok the new break out board, power supplies and speed control interface mounted and ready for wiring..
    Rick
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
