Thread: Which Software
Rob,
No offence taken, but and its a big but that machine is double your budget adding in the software and it only has a low duty spindle
And its only taking shallow cuts, as soon as you start increasing the thickness of cut the problems will show up.
Phil
09-12-2010 #2
im kind of hoping your not entirly right phil, iv spent about 2k and although i dont intend to cut to much alli im hoping it will if i need it to
im thinking small cuts will be fine.... thats the beauty of cnc (if its running well) press go have a cup of tea watch some telly scratch your arse and swagger back into the shed with a de-burring tool to a nice shiney finished part
09-12-2010 #3
10-12-2010 #4
hi rob..... errrrrr i might be lieing a bit..... we'll find out (ish)
25mm thk slides for the X and Y 20mm thk Z £250 ish
1605 ballscrews £300 ish
heavy extrusion £500 ish
20mm alli plate £400 ish
5 axis chinese stepper kit+power supply £260 ish
ball nut housings £150
so far thats £1860
im pretty sure iv spent at least £100 building 3 spindles including buying the speed controller
theres easy another £100 on odds and sods like timing pullies micro switches cable
i could be looking at £2100/£2200
it might be more though,,,,, stuff has a way of sneaking under the raydar :)
have a read of "fingers crossed it'll cut ally" you might spot somthing in there that iv missed
its quite an exspensive one for a first build but im pretty sure i wont need to build it again and its a lot cheaper than buying one off the shelf
10-12-2010 #5
Yeah it's scary when you add stuff up, best not to do it huh! Good luck with it fella! My only option is an off the shelf machine as building one would take me 47 years and would make my brain explode...
10-12-2010 #6
software
By rainboweyes in forum Computer SoftwareReplies: 4Last Post: 09-02-2013, 11:59 AM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
New Software
By luke11cnc in forum CAD & CAM SoftwareReplies: 5Last Post: 14-09-2011, 06:00 PM -
What software can do this ?
By Kammo1 in forum Computer SoftwareReplies: 4Last Post: 05-04-2010, 07:57 PM -
What software ??
By Kammo1 in forum Computer SoftwareReplies: 11Last Post: 07-09-2007, 01:46 PM
