Page 2 of 2 FirstFirst 12
    Guys i think you both have run away with this one...LOL! he just wants to get his lathe up and running in a quick turnaround. No mention of servos and taping etc or even CNC?
    I would like a servo controlled lathe though. I keep looking at a place i know for a decent servo suitable to build one from scratch. He takes them off the scrap and normally tosses them to one side. A servo to replace a 3hp equivalent motor would cost a lot of wonga?
    Quote Originally Posted by 2e0poz View Post
    Always good to have as much info as you can.
    Hood on the Mach3 forum uses a 14 hp servo and he's a Scot.
    Phil
    Sent from my HTC Desire using Tapatalk
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Either 350+vat or 434+vat from zapp depending on if you want speed or torque in the 2.3-2.4kw range.
    Plus another 304+vat for a suitable drive...
    Getting back to the original post, I got a custom step-up transformer made to build a RPC, but I can't for the life of me remember the name of the company.
    Regarding getting a neutral, if the idler motor is a 240/415V motor, then when wired in star config for 415V operation, the star point will provide a neutral for the three phase. That's how I use a 240v contactor to drop out the start capacitors once my RPC idler is upto speed. However, the neutral will be at 240v in relation to earth, instead of the usual 0v, and with the transformer acting as an isolator, you've got to be careful of electric shocks. I installed a three phase RCD as part of my RPC to minimise the risk.
    Phil agree lots of info is always good to have and the price of servos and drive could almost buy a brand new lathe. Certainly not a cheap option? Factor that cost into a scratch build though would be a more viable option? i like it already?????????????? :-)
  1. NEW MEMBER: Not another Newbie!
    By LawcockLD in forum New Member Introductions
    Last Post: 07-06-2014, 11:22 PM
  2. NEW MEMBER: Newbie to CNC
    By thuncle in forum New Member Introductions
    Last Post: 12-09-2013, 07:13 PM
  3. NEW MEMBER: Not another newbie!
    By andyl in forum New Member Introductions
    Last Post: 05-02-2013, 09:55 AM
  4. NEW MEMBER: Newbie
    By Dieseldog in forum New Member Introductions
    Last Post: 27-01-2013, 08:39 PM
  5. NEW MEMBER: Hi from Wiltshire.
    By mikec in forum New Member Introductions
    Last Post: 24-06-2009, 05:46 PM
