Thread: Need some ideas
Yeah come on then lets have a listen...lol
Another idea I hed was a cylinder with a very abrasive rotating flat disc to almost grind it away into a heavy dust?
29-01-2011 #2
You have say five rubber faced rollers set two over three, similar to Olympic games emblem, in the centre of the rollers is a groove, this groove forms a channel to feed the cord to the die.
The rollers are 24mm diam they then feed the cord to a die the other side of the die is a rotating disk with six holes that form a shearing/scissor action.
The rollers and the disk are geared to run together, so one revolution of the rollers cuts 6 pieces of rubber at 4mm long, at 200 RPM you are cutting 4.8 metres per minute.
Phil
New Gantry Ideas
By Tomnewry in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 05-02-2014, 10:00 PM -
BUILD LOG: 5'x3' Ideas and build.
By Wal in forum DIY Router Build LogsReplies: 17Last Post: 29-12-2012, 02:03 AM -
New machine Ideas
By jcb121 in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 19-09-2012, 10:18 AM -
Ideas and inspiration....?
By Tom in forum General DiscussionReplies: 20Last Post: 10-08-2010, 01:09 AM -
Any ideas on the best use of this????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 01-08-2010, 11:41 AM
