    Just been testing my new 2.2kw spindle, and this is the first thing I've done with it:
Name:	DSC07004 (Medium).JPG
Name:	DSC06995 (Medium).JPG
Name:	DSC07006 (Medium).JPG
Name:	DSC07005 (Medium).JPG
    Anyone want one :naughty:?
    Backlash has caused the lettering to be a little off, but it's not really noticeable.
    It seems that carbon fiber is quite easy to cut with those cheap diamond burrs...
    I'll post a video tomorrow.
    Can i order one that says "MYCNCUK" please :whistling:
    Looking good so far though, another member wanted to machine fiber but wasnt to sure how well it would work as its a hard material, i guess this answers the question.
    Don't see why not, I'll make you one next time I go home - not got time now.
    I'll put some details here just in case he's listening!
    In the past I've had problems machining it because it is very abrasive. At first I tried a 4mm HSS cutter I think it was in my milling machine at 2150rpm. That worked, but after one small part the cutter was polished and ruined.
    Then I tried the diamond burr in the milling machine which worked very nicely leaving a smooth finish. However with the spindle speed limited to just 2150rpm, and this basically being a grinding operation I could only use about 60mm/min, if that. Not surprisingly it took forever - however the cutter lasted.
    Now with over 10 times the spindle speed it cuts easily. I trimmed the carbon sheet at 450mm/min (24000rpm), and cut the keyring out at 180mm/min. No doubt it would do more on a more rigid machine. I didn't want to push it since that's my last cutter...
    It still looks fine after cutting about 1m of carbon.
    Does anyone know where I can buy several of this type of diamond burr, not an annoying set with all sorts of shapes? I looked a while ago but could only find the latter for a reasonable price.
    Very smart Jonathan. What software did you use to create the text?
    Regards
    Ian
    I used Techsoft 2D design, which I got from school, to draw it all. It's got some fonts which are composed of single vectors which makes them good for engraving.
  1. FOR SALE: Carbon Fibre Sheet 2mm (all carbon 3k)
    By richie00boy in forum Items For Sale
    Last Post: 27-02-2015, 08:44 PM
  2. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  3. Which of these bits for carbon fiber and fiber glass?
    By craigrobbo in forum Tool & Tooling Technology
    Last Post: 28-02-2013, 01:03 AM
  4. Carbon Fibre Sheet
    By richie00boy in forum Marketplace Discussion
    Last Post: 12-01-2013, 07:46 PM
  5. Cutting Carbon Fibre
    By Tenson in forum Machine Discussion
    Last Post: 18-05-2012, 02:21 AM
