Thread: Ragged edges
Page 2 of 2 FirstFirst 12
    There is a reason why router bits don't have a helix on the cutting edges, as you just discovered :heehee:
    The helix adds an upward component to the cut.
    I've bought a down-cutter but haven't tried it yet. Been too busy making solar panels, wind turbines and solar cookers!!
    Quote Originally Posted by Minnican View Post
    Nice, I've made all of them too! Probably the main reason I made my CNC router is to do wind turbine blades. Bit off topic, but here's the solar panel (tracking parabolic mirror etc) I made a few years ago:
Name:	DSC02311 (Medium).JPG
    Got any pictures of what you've made?
    Edit: Thought I'd add something on topic. Before I got router cutters I did once have to use a normal milling cutter on plywood - it did make a huge difference.
  4. Quote Originally Posted by Jonathan View Post
    Jonathan, very nice mirror. Does it have sun tracking system ??
    Minnican, yes I want to see some pictures as well :) Very interesting subject
  5. #15
    Quote Originally Posted by wiatroda View Post
    Yes it does - that's what the small PV on the top right powers. There's a small geared motor with a linkage to track the mirror. The mirror rotates on bearings placed around the focal pipe. You can just about see the temperature in that image - that's in Celcius. I've seen about 160C on it. I will post a better picture later when I've found it.
  1. RFQ: Drill/Tap Guide Block for 15mm aluminium plate edges.
    By Wal in forum Projects, Jobs & Requests
    Last Post: 29-11-2012, 04:23 AM
  2. Milling experts, end mills cutting edges different lengths ?
    By Smiler in forum Tool & Tooling Technology
    Last Post: 14-02-2009, 10:13 PM
