Page 2 of 2 FirstFirst 12
  1. Here's pic of the mill on its stand... (sorry its so tiny but thats a limit of the forum... Lee - needs fixing soon)
    I keep getting a mad urge to drop a few chunky spiral reinforcement rods down inside the column of mine, then top it off with a rich cement mix. The rods are there ready for next time I'm doing concrete.
    You have excellent access to plug the bottom of your column and do the same. Could be useful :D
  3. Quote Originally Posted by Robin Hewitt View Post
    And the benefit would be??? I'd imagine a modicum of additional stiffness? Kip is looking at a square column conversion for his which sounds interesting. He's apparently talking to an iron foundry, presumably because its too big a casting for him to do...
    Ah! You are still at the "this is a chunky looking hunk of iron" stage of your development.
    Bliss
  5. Quote Originally Posted by Robin Hewitt View Post
    Bliss
    You been trying those big cuts again Robin...
    :D
  6. #16
    :D
    Big cuts are fine so long as your screws are tight enough to prevent the dig in. You just make it oversize for the big cuts. I'm actually amazed how much metal these mills can hog out without breaking the tool, usually when it throws a wobbly and decides to plough off in some unexpected direction.
    The time when you feel the flex is when you're going for that fine finish. It turns a corner, a sympathetic vibration sets in and you start to wonder if another few hundred lbs of metal might not be a really good idea.
    I'd also fit backlash free splines in the column if only I could get it apart :D
  1. Font help, adding a stand/base to letters so they stand up
    By cockneyrebel in forum Computer Software
    Last Post: 25-07-2014, 12:57 AM
  2. Replies: 0
    Last Post: 06-02-2014, 09:52 PM
  3. How are these made...
    By jashington in forum General Discussion
    Last Post: 31-10-2013, 08:07 PM
  4. What does ER stand for in "ER11 collet"?
    By bruin in forum Tool & Tooling Technology
    Last Post: 06-09-2012, 01:36 PM
  5. My home made CNC mill
    By pjm in forum DIY Mill Build Logs
    Last Post: 07-06-2010, 12:01 AM
