    For sale,
    3 x Driver 25PS (DiyCNC boards).
    2.5 amp at 30v max.
    Only used for a short amount of time.
    http://www.diycnc.co.uk/html/driver25.html
    £15 each.
    would these be ok running from a cheap 24v 10a power supplies?
    and could I hook it up to something like this http://www.diycnc.co.uk/html/pcpps.html
    and have quite a cheap setup?
    They would run from that power supply. The problem is 30v (let alone 24v) is not enough to run most Nema 23 stepper motors effectively. The higher the voltage you run the motor on the higher the speed you can get since the torque drops off less rapidly. It's because the inductance of the stator coils limit the current that can flow at a low voltage... v(t)=L*di(t)/dt
    You want at least 50V ... general rule is required voltage=20*L^0.5 where L is the motor phase inductance.
    KK I'll be getting some others then,
    sorry Micheal,
    Quote Originally Posted by jcb121 View Post
    Yes,
    Providing you are not trying for a low earth orbit then yes they will work satisfactory and give you what you are asking for, a cheap setup.
    John S -
    Yes,
    True, I might have been a bit quick to assume that he wanted to run the motors optimally. It would be cheap. I think it's the 3Nm motors... so they would have to be used in Bipolar-series which doesn't help matters.
    I started off with 1nm motors and a unipolar stepper driver on my milling machine. It worked, but snails go faster than the 1mm/s it did.
    Hi, I was using them to run some 23 frame 2Nm motors, easily did 600rpm which was more than enough for me.
    With my 3mm ball screw I got feeds of 1800mm per min no trouble at 24v.
    Cheers.
    Items are now sold!
    Good,
    Now use the money to get a new avatar, the one you are using is butt ugly, it's even worse than the old one.
    John S -
    Good,
    Cheers John!! Did you get the lathe back in good order? Will pop round to your sometime soon.
  1. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
  2. 240v Stepper drivers
    Last Post: 10-11-2012, 12:57 PM
  3. Setting up stepper motor drivers
    By croy in forum Motor Drivers & Controllers
    Last Post: 30-09-2012, 09:51 PM
  4. FOR SALE: Stepper Drivers + PSU's
    By Shinobiwan in forum Items For Sale
    Last Post: 16-03-2012, 11:05 PM
  5. High voltage stepper drivers?
    By ZeroCount in forum Motor Drivers & Controllers
    Last Post: 26-02-2009, 12:07 PM
