    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,989. Received thanks 373 times, giving thanks to others 9 times.
    Depending on how many you want to make, it may be more economical to have a custom die made that can do a complete V without having to turn the metal over.
    It would also have the advantage of keeping any score marks from the female die on a single side of the metal.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. Quote Originally Posted by m_c View Post
    I am thinking 12 panels will be plenty for now for my own home DIY projects.
    Ah you mean these types of corrugating press brake tools?
    Such tools would need to be custom made to the right profile so I think we are talking many thousands for 2 metres of such tooling, maybe even more than £10,000?
    Now, OK, if a company was producing many panels, then such a specialist corrugating tool would be a good investment but I only need 12 panels for just now so a small custom grind of a standard tool is about all I can afford.
    I believe there is urethane film available which is designed to be inserted under and over the work sheet to protect the sheet against marks from the die.
  1. RFQ: Gantry side panels
    By fvfdrums in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 03:50 PM
  2. RFQ: Panels cut from soft plywood
    By Rockeyes in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 04:38 AM
  3. RFQ: MDF Panels (+ More)
    By codytom in forum Projects, Jobs & Requests
    Last Post: 09-04-2013, 09:16 PM
  4. Where to get 1/8" sheet mild steel laser/water jet cut?
    By HankMcSpank in forum Marketplace Discussion
    Last Post: 10-02-2010, 01:28 AM
  5. Drill/Mill Spindle brake (RF30)
    By BillTodd in forum Machine Discussion
    Last Post: 04-11-2009, 12:09 AM
