Thread: Steel Router 610 x 1220 x 200
18-08-2011 #12
I only need mounts for the y and z. The x ballnut will be fitted in a hole in center of the 50x100, you should be able to see it in the pic.
I can send you the proposed new drawing to give you an idea, but I would like hold off on actually making the z until I get the linears screws and mounts so I can double check the dims.
It will be probably a month or so if that's ok with you, what format do you want the drawings in(it's drawn in solidworks so I can save it in most formats).
Don't worry about how long it takes as I will probably be getting the linears before I have finished building the frame anyway.
As for the material We can sort that out nearer to the time, in the mean time I will be keeping my eye out for a good deal.
Does anyone know of a good steel box supplier, or am I better looking for local places?
WANTED: 3 bits of 250 by 1220 by 40mm t-slot, 1220 16X5 threaded rod and isel ballscrew, plus
By nobby in forum Items WantedReplies: 1Last Post: 01-03-2014, 01:31 AM -
BUILD LOG: Steel Framed CNC router
By Joe in forum DIY Router Build LogsReplies: 14Last Post: 23-06-2013, 10:45 PM -
BUILD LOG: Formed steel cnc router
By sbams in forum DIY Router Build LogsReplies: 4Last Post: 07-03-2013, 02:00 AM -
BUILD LOG: Steel Framed Router
By GTJim in forum DIY Router Build LogsReplies: 52Last Post: 14-09-2011, 06:51 PM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
