Thread: Advice on some basic tools
You can also make your own welder very very cheaply with microwave oven transformers. Remove the 2KV and heater secondary windings, and replace it with the right number of turns of some very thick wire.
I started making one but soon after spotted the one at Aldi.
http://www.google.co.uk/search?aq=0&...sformer+welder
21-09-2011 #2
Hmm. A voltmeter attached to the workpiece and to the stick will measure (approximately, considering voltage drop etc over the length of the stick) the arc voltage when in use. Could you electronically sense when the arc kicks in and the welding starts, in a way that would allow a computer to effectively control stick distance from the workpiece?
The ideal CNC machine for my (basic)needs?
By mark84 in forum Machine DiscussionReplies: 9Last Post: 12-03-2014, 10:56 AM -
RFQ: Basic Error! - anyone have a lathe, some 10mm steel stock and a few mins please?
By TonyD in forum Projects, Jobs & RequestsReplies: 5Last Post: 14-10-2013, 06:20 PM -
WANTED: Basic 3 Axis CNC breakout board.
By Philly in forum Items WantedReplies: 1Last Post: 29-09-2012, 10:39 PM -
NEW MEMBER: Basic 3d milling
By proddy in forum New Member IntroductionsReplies: 3Last Post: 08-06-2012, 12:11 AM -
Which Basic Lathe
By graysclassics in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 06-07-2011, 10:39 PM
