  1. #19
    Steve has hopefully already reduced the kernel speed as I mentioned it early in this thread (#17). Perhaps not I was not forceful enough.
    Seem to remember Steve saying he was running 35K thats why mentioned running 25K.! . . . Obviously it's the bent screw thats now Screwing him..:cry:
    If it's 800step/rev then on 25kHz with 10mm pitch screw and direct drive the maximum feed is 25000/800*10*60=18750mm/min ... so plenty. Clearly half that with 1600, which it sounds like is still a lot more than your machine will currently do.
    Well yes those figures are right in Theory regards what Mach could actually put out in pulse's but in actual practice 1/1 direct drive on 10mm pitch then a realistic usable figure is 8000mm/min 10,000mm/min Max due to running nema 34's which 800rpm is about the norm and 1000rpm would be about max.
    Steve was getting close to half this lower figure with bent screws so when every things running straight and true I'm sure he will reach these figures. . . . I'd also wager at higher M/S as well if he was indeed running 35K not 25K.?
  1. Digital Drivers and Stall Detection
    By Washout in forum Motor Drivers & Controllers
    Last Post: 10-12-2013, 05:02 PM
  2. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  3. RFQ: Z axis and y axis carriage
    By D-man in forum Projects, Jobs & Requests
    Last Post: 08-04-2013, 10:06 AM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
