80 x 80 x 6 box section can still distort. The size of the machine you are building will be rather heavy, 80 x 80 x 6 box section aint light. Unless you level it very well it will still move. If you decide to bolt it down then make sure it is perfectly level on its feet or you will pull it out of alignment with the bolts.
Ian
13-10-2011 #2
We would certainly be interested in hearing the personal experiences of anyone who's used epoxy et al to level the top rails of a larger frame. Our Mark-3 machine will be for 8' x 4' sheets. (That said, we're still assembling the bits for MK-2).
Karl
13-10-2011 #3
14-10-2011 #4
No I dont think the material is oversized.
If you want a really sturdy machine then you cant really oversize the frame material, within reason I might add. Box section steel itself isnt really that strong unless you start going into heavy wall thickness stuff and as Jazzcnc has said getting your construction right to start with will make all the difference and would save you £800 on machining.
Ian
13-10-2011 #5
Yep, anything will distort. It's a matter of how much and the effect it has.
Heavy frame = good, as long as you don't have to move it!
For a machine purely for woods it does seem a bit excessive, however you seem to want to use it for milling aluminium too in which case it pays to make it as strong as you can.
What sort of tolerances do you require as that it what determines if machining the rail surfaces perfectly parallel is necessary? You can compensate for it perfectly well in software.
13-10-2011 #6
15-10-2011 #7
If you are not bothered about weight, why don't you buy an old machine and fit new drives and electronics. i would have thought you are more likely to achieve the level of accuracy you require.
17-10-2011 #8
17-10-2011 #9
what about this: http://www.ebay.co.uk/itm/Wadkin-UX-...item231485a663
18-10-2011 #10
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
What frame bed and where to buy?
By icedfusion in forum Machine DiscussionReplies: 11Last Post: 13-01-2012, 06:39 PM
