19-10-2011 #2im assuming when you say "rails" you mean the frame or rail beds ?As a result I have looked at casting the rails using epoxy granite and reinforced plastic beams
i like the idea of epoxy granite, i dont like the idea of casting around the plastic I beams.... if your going to the trouble of casting a base anyway why go to the bother of using the I beams..... if its about keeping the "volume to weight" ratio down id be tempted to just cast around foam or polystyrene blocksLast edited by blackburn mark; 19-10-2011 at 11:14 AM.
Laminate plastic help!
By totts in forum Marketplace DiscussionReplies: 7Last Post: 13-04-2013, 07:14 PM -
Some kind of plastic needed
By m_c in forum General DiscussionReplies: 26Last Post: 08-04-2013, 12:29 PM -
x-axis rails and lead screw
By adambrum in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 13-08-2011, 01:56 PM -
2 ply plastic help
By h4ppy-chris in forum General DiscussionReplies: 8Last Post: 30-01-2011, 04:54 PM -
Looking for thin plastic? sheet
By irving2008 in forum Machine DiscussionReplies: 19Last Post: 09-09-2010, 12:32 AM
