Thread: Top speed failing after a bit
10-11-2011 #5
Nothing wrong with a bit of healthy paranoia, so long as you can rise above it
My mill worked at 25mm/s for a couple of parts then failed one lift.
One failure in one axis and I'm seriously considering cutting all axes below 20mm/s forever more. Obviously I think the machine is out to get me.
What I should do is figure out why 25mm/s failed, fix it and go for 30mm/s. :naughty:
Safe Z Speed
By dudz in forum Artsoft Mach (3 & 4)Replies: 23Last Post: 24-05-2014, 04:08 PM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Speed control
By Saracen in forum Spindles & Drive MotorsReplies: 2Last Post: 29-12-2012, 02:18 PM -
Adjusting speed with vfd
By motoxy in forum Spindles & Drive MotorsReplies: 8Last Post: 24-09-2012, 04:07 PM -
speed controler
By Scott in forum Machine DiscussionReplies: 13Last Post: 04-11-2010, 10:02 PM
