Thread: wiring e-stop button
21-11-2011 #7
Yes this works ok for killing motion but it won't do much for you if the spindle grabs you. Plus interia will still move a powered stepper if going fast eneough.
If you want a truely safe EMERGENCY STOP then you kill power and that includes the spindle. . . It's not difficult or expensive just a few relays and some wire.
Lots of folks think because it's just Hobbie CNC then this level of safety hisn't required. . . this will be ok 99% of the time but it only takes 1% to chop your fingers off or crush your hand.!! Even the smaller steppers will crush your hand in the blink of an eye just as will the light duty trend/kress spindles slice your fingers off.! . . . His it worth the risk for £10-15 quid more.? Not to me it hisn't. . . .To use none at all is just plane stupid.!
Help with Mach 3 REF all Home Button
By Kevin1970 in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 23-04-2015, 10:54 AM -
Mach3 Using a physical button to repeat current gcode
By RLKS Rob in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 12-08-2012, 01:30 PM -
Donate Button
By Ricardoco in forum General DiscussionReplies: 8Last Post: 08-09-2011, 10:32 PM -
Machine co-ordinates button in Mach 3
By alan2525 in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 14-04-2010, 10:57 PM -
Wiring in power and E-stop on DIYCNC Board
By m.marino in forum General ElectronicsReplies: 2Last Post: 10-05-2009, 10:15 AM
