Agree, stepper would greatly ease and speed up a job.
It's not cranking itself , but pulling back handle to unlock is painful as the spring is really strong- too strong.
My rotary has 4 slots and fits nicely to four mounting holes in a chuck
How about programming rotary table- looks like hand written G-code for me.
What about making some macro with some loop working until machine cut desired amount of tooth???? some no. of tooth variable in a macro??
14-12-2011 #2
I didn't use a dividing plate, never really seen the point when the rotary table has a scale which just move to the right angle.
If you use EMC you can do it in just a few lines of code as, unlike mach3, it supports loops. I just wrote a quick program to write the code for pulleys:
http://www.mycncuk.com/forums/showth...ating-programs
The main reason I did that program was for milling XL pulleys using just a normal endmill, but you can use it with a form tool too.
14-12-2011 #3
Double post, deleted.
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Y axis is making X axis stall...!!
By fasteddy in forum Machine DiscussionReplies: 83Last Post: 24-10-2011, 12:19 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
