    New meaning I haven't seen it before...
    Stated accuracy on the 2mm ruby tip is .001" (0.025mm) which is not hugely impressive, but the £140 shipped price ticket is.
    http://www.ebay.co.uk/itm/160711238923
    Opinions? Thought I'd ask before I got one, rather than get told I was a twit after the event :heehee:
    Robin
    Aw bollocks to it, it's only 140 quid, I just bought one.
    Twit status can be determined when it arrives :naughty:
    Only!
    It will be interesting to see how it compares to a homemade one. They mention about using different metals for the contacts to stop carbonising. I wonder if the contacts are gold plated, or if there's more to it than that. If so then I'm sure one could find some gold plated connectors to use as contacts to make one.
    I'm still waiting for Jonathan to make me one
    http://www.mycncuk.com/forums/showth...ch-Probe/page3
    James
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 1 Week Ago Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Hi Robin,
    How was this probe ? Does it glide over the objects like in the youtube video ?; CNC USB Controller - Digitizing 3D model with probe - YouTube
    Touch probe cmm digitizing renishaw haas fadal cnc mill lathe router engraver | eBay
    Robin
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    I bought one of these, took about 10 days to arrive, been using for a week now. Very impressed so far, been using it to measure some T1 injection mouldings, mainly for hole positions. I am struggling to work out how to get it to probe a "boss". Just started to do some forum searching and may well contact the supplier to help solve this problem. I needed to buy the license (£18.50) to be able to calibrate the probe and measure lots of holes, but hey £18! Simon
    dudz's Avatar
    Ive had one for a while now. Dont use it, cus no software out there that's good and cheap
    What are you trying to use the probe for?
    dudz's Avatar
    Quote Originally Posted by Cube3 View Post
    copying. Getting point clouds. All the free stuff is rubbish.
    Wanted a program that would get point clouds and convert into mesh all in one.
    dudz's Avatar
    Seems this must be relatively new technology . Vectric doesn't have software that does it all from point clouds to mesh to dxf.
  1. Touch Probe Project
    By Washout in forum Tool & Tooling Technology
    Last Post: 20-11-2013, 12:59 PM
  2. Touch probe stylus - where to buy?
    By Mad Professor in forum Marketplace Discussion
    Last Post: 05-08-2013, 07:07 PM
  3. Touch Probe
    By luke11cnc in forum Probing, Digitizing & Scaning
    Last Post: 31-01-2012, 01:16 AM
  4. RFQ: Touch Probe - Lathe job
    By cooliced in forum Projects, Jobs & Requests
    Last Post: 16-11-2011, 07:12 PM
  5. Replies: 1
    Last Post: 29-05-2011, 08:15 PM
