Thread: calibration
    step/mm is 85.46301769
    James
    Quote Originally Posted by luke11cnc View Post
    That's very interesting...I just don't see how with 30T pulley on motor and 15T pulley on the 10mm pitch screw it could be anything other than 80 step/mm. Unless the pulleys got mixed up somehow. Sounds silly but could you count the teeth on the Y-motor pulley. I reckon bearingstation accidently sent me 28T pulleys and neither of us noticed as that gets 85.71429 step/mm which is very close. If that's the case you should check Z and put the 85.714 in for Z.
    Jazz did you arrive at that number by scaling and measuring, or some calculation?
    I could tell you but then I'd have to kill you.!!. . .:rofl:
    I did nothing other than explain to James how to let Mach do all the hard work and use the Set steps Per unit feature on the settings screen. . . . Simplizzzzzz
  1. Calibration issues, advice needed
    By Kernow Jim in forum Motor Drivers & Controllers
    Last Post: 23-01-2014, 07:18 PM
  2. Problem with calibration
    By m.marino in forum Gantry/Router Machines & Building
    Last Post: 22-04-2010, 04:19 PM
  3. Chronoscope Calibration Tool
    By Robin Hewitt in forum General Electronics
    Last Post: 29-11-2008, 01:26 AM
