The reversed direction was a joke right? I think it confused a few.
Anyway it does sound like wire, as said just move it to a malfunctioning position and test the continuity with a multi-meter. At the motor end you probably don't have access to the bare wire so you could push a pin through the wire insulation into the core and then you can test from that.
To be honest though, wire doesn't tend to break, the connection points do, at the plug and at the motor. You might end up needing to open the motor case to check where the wire joins.
20-02-2012 #2
No joke sadly, thats what it does. Starts out on z+ for instance then reverses to z- or other way round.
If i jog the gantry around i can feel that there is little power on the zaxis motor because i can move it manually until it gets to a position on the bed where power has obviously been restored, then it feels similar to the x y motors. Guessing that its a cable/connector problem of some sort. On closer inspection the cables do not look new and are probably reused.
Chinese Nema 34 packages on ebay
By adamh in forum Marketplace DiscussionReplies: 4Last Post: 06-12-2013, 12:24 PM -
Chinese CNC machines - Request
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 03-05-2012, 05:55 PM -
NEW MEMBER: Just purchased Hardinge HL TFB tucson arizona usa
By jimbocafe in forum New Member IntroductionsReplies: 1Last Post: 19-12-2010, 02:45 PM -
Used Routout CNC Recently?
By CraftyGeek in forum General DiscussionReplies: 1Last Post: 17-07-2010, 12:37 PM -
Purchased a Taig CNC Micromill from Ebay
By alan2525 in forum Marketplace DiscussionReplies: 10Last Post: 16-04-2010, 10:53 AM
