    Hi Everyone,
    I have 2 ballscrews for sale. I think they would suit a small mill rather than a large router etc. I thought I'd offer them here first rather than eBay.
    Number 1 is a 7.5mm dia 2.5mm pitch screw and has been machined at the drive end to 6.3mm, the other end comes complete with thrust bearings and locknuts. The ball nut has an M15 fine thread on it. Total length is approx 300mm. This screw is ready to use and I think would be ideal for a Z axis.
    Number 2 would require machining, it is an 11mm dia, 4mm pitch screw approx 780mm long. One end is machined for thrust bearings but the machining is imperial and so the bearings and nuts are not easy to source. I would remachine for metric bearings. The Ballnut is fixed by an M20 fine thread.
    I bought them on EBay when I first thought of building a machine but as you will have seen from my build log, my machine outgrew my initial ambition:). Remember, if you want these screws to factor in the cost of machining and the taps for the ballnuts (but I've seen them epoxied into the plate before now by skinflints:))
    Both screws are rolled type and I was told they are by SKF, certainly the Ballnuts are available at RS at their usual amazing prices. They are used obviously but seem to have had very little wear, can't see any rust etc on them and the nuts both run very freely.
    £25 plus postage for both, I paid a lot more.
    I have attached photos, sorry for the quality, if you need better ones, just ask.
Name:	DSC00011 [640x480].JPG
ID:	86   Click image for larger version.
Name:	DSC00010 [640x480].JPG
ID:	87   Click image for larger version.
Name:	DSC00019 [640x480].JPG
ID:	88   Click image for larger version.
Name:	DSC00016 [640x480].JPG
ID:	89   Click image for larger version.
Name:	DSC00017 [640x480].JPG
ID:	90   Click image for larger version.
Name:	DSC00020 [640x480].JPG
ID:	91   Click image for larger version.
Name:	DSC00013 [640x480].JPG
    Hi Jeff, nice listing ! the images dont seem to be loading mate.
    Hi Lee,
    Should be fixed now:)
    Kl, i maybe considering these for the mill im making so ill let you know.
    Also, use the site Media Centre for storing your pics mate :)
    Ok Lee, thanks for the heads-up re the media centre. It'll make the forums a little less confusing.
    Np's also means you can just use a bb code to post in your pics to any post/forum.
    Just seen the ad, do you still have these for sale? If so I will have them.
    You going to sell them Smiler ?
    Smiler, if these are still available I would like to buy them, please let me know total including postage.
    SORRY!!!
    I thought I'd replied to Garry when he offered to buy them and it just left my mind :(
    If Garry doesn't need them now, Jon can certainly have them.
    Regards and sorry to all, Jeff.
  1. Delrin Lead nuts.
    By Kammo1 in forum Gantry/Router Machines & Building
    Last Post: 27-01-2016, 08:36 PM
  2. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  3. WANTED: Metric feed nuts for bridgeport
    By Philmollatt in forum Items Wanted
    Last Post: 05-06-2010, 04:46 AM
  4. Any CNC nuts in London - here on holiday
    By Greolt in forum General Discussion
    Last Post: 15-01-2009, 11:44 PM
