Has Chai given you any load ratings or datasheet for these twin start screws? Would be interesting to see how they compare to the single start. Do the ball-nuts have two or four rows of balls and are they the same dimensions as the single start nuts?
21-03-2012 #2
Spot the difference.!!! . . . . Can You see know how I didn't spot It was 10mm pitch straight away.!! . . .The nut length gave it away.
3 circuits (rows) 6 plugs. 3 circuits is a typical for 16mm dia, 4X usually on 20mm and above.!
As you can see quite a bit longer body and obviously ever so slightly more resistance due to extra set of balls.
No didn't get any Datasheet, I didn't even know he was sending me twin start so didn't ask. I will email him to see if he as any specs.
Will be a couple of weeks before I have them on the machines and working so will let you know how they perform.?????
Centec 2 ballscrews
By jonnydeen in forum Lead Screws, Nuts & SupportsReplies: 29Last Post: 11-07-2023, 09:53 AM -
Bended ballscrews. What i can do?
By ba99297 in forum Lead Screws, Nuts & SupportsReplies: 25Last Post: 13-04-2017, 01:41 PM -
Best place to get ballscrews?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 15-04-2013, 10:09 PM -
pictures of ballscrews??
By wilfy in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 28-10-2012, 09:09 PM -
FOR SALE: RM1610 ballscrews(used + 1605 x 900mm screw (new)
By rbs in forum Items For SaleReplies: 1Last Post: 10-05-2012, 08:23 PM
