Thread: Another Newbie
Ah coolant, I hadn't thought of that.
I guess that means I could't have any board involved.
I had thought I might clamp the working sheet to a sacrificial piece of board.
Mmmm, there is always something
25-04-2012 #2
Not a problem just use plastic sacrifical board, hdpe is what I use very flat and stable? . . .BUT a far bigger problem you will have with small items like this is the actual clamping and holding.? Unless they have holes for screwing or clamping thru then it's a night mare holding small items for profiling.!
The thinner the material the worse the problem, I often spend more time making holding fixtures, jigs or repositioning clamps etc than the actual parts take to machine. IE: Recently machined some small Brass items and the total Job time was 30 minutes per 4 buckles the machining time was 17mins the rest was made up having to swap clamp positions without disturbing position and 1 tool change(2mins max).
25-04-2012 #3
I can see myself trying this sort of job... Would tabs solve the problem Jazz??
25-04-2012 #4
I wonder if some kind of picture frame might work.
Slide the sheet in, make the cuts.
25-04-2012 #5
Yes they work for some jobs but not all and with really thin material or small parts then there's not much left for the tab and they break or let the part lift.
On small parts I often leave a thin skin 0.1-0.2mm and don't actually cut right thru so it's kind of like a one big tab then just clean up with de-burr tool or quick blast across the sander and the skins gone, tabs on small parts don't really work very well.!
Chris the problem comes from when you do the profile or outside cut thru the material, if not held down it will get grabbed or flung by the cutting tool. No sicker feeling than seeing a beautiful part which took 2 hours machine time come to life only to get chewed up and spit out in 2secs.!!
Clamping is probably one of the most un-thought about and time consuming things in DIY CNC.!! Unfortunatly the smaller the parts or thinner the material the worse the issue the more the need to get a good system in place.
If you have any thoughts to make multple identical parts then it's often worth taking the time to make a dedicated Jigs.!
25-04-2012 #6
25-04-2012 #7
Anyone got a comment on this machine.
Seems to tick a lot of boxes for me.
26-04-2012 #8
There's a similar thread running here that you might find useful;
27-04-2012 #9
I've been trying to get my head around this tab/skin business.
Are you saying that after cutting out I would use something like an orbital sander to remove the skin ad drop each piece out of the sheet.
Would a deburring tool go through a tab of say 0.2mm skin or tab?
Chris
27-04-2012 #10
If anyone is replying specifically to me I have now started a build thread here, so maybe you could reply there - cheers
NEW MEMBER: Another newbie
By Moddsey in forum New Member IntroductionsReplies: 0Last Post: 27-05-2014, 11:08 AM -
newbie needs help
By pauley555 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 05-07-2012, 09:48 PM -
NEW MEMBER: CNC Newbie
By packman in forum New Member IntroductionsReplies: 6Last Post: 11-05-2012, 10:07 AM -
NEW MEMBER: newbie
By stevedemicoli in forum New Member IntroductionsReplies: 5Last Post: 31-03-2012, 10:12 AM -
NEW MEMBER: Newbie here
By Mr Tim in forum New Member IntroductionsReplies: 0Last Post: 23-08-2011, 08:50 PM
