    I recently found a Clarke CL250M micro lathe for a good price, so I got it to convert to CNC. This lathe is very similar to the C1 micro lathe from Arc Euro.
    Parts bought:
    Unfortunately I didn't take many pictures to start with, so this is going to be more like a 'look what I've made' in parts than a build.
    Not a chance of getting an RM1204 ballnut in the cross slide, let alone two, so I've mounted them behind. To do this I milled a block of steel to extend the saddle for the ballnuts' mount and drilled it:
Name:	DSC09374 (Medium).JPG
    Next I turned some 3.5" aluminium bar to accommodate a two ballnuts, one in each end:
Name:	DSC09376 (Medium).JPG
ID:	5872Click image for larger version.
Name:	DSC09378 (Medium).JPG
    One ballnut fixed in this side:
Name:	DSC09382 (Medium).JPG
    The other goes in this side. On 'top' of that goes a steel spacer, then and end cap to accommodate a pair of beleville washers. This cap is bolted through the ballnut to apply a preload of about 300N and rotationally constrain the ballnut:
Name:	DSC09383 (Medium).JPG
    Cut the aluminium motor mount on my CNC router. Just a few 5/8" thick aluminium plates with a cavity between to accommodate the pulleys so that swarf cannot get in the belt drive or bearings. I used a 12T pulley on the stepper motor and 30T on the ballscrew for 0.008mm resolution with a 200step/revolution stepper motor. If you count using microstepping it's a convenient 1um resolution. Once assembled I put a DTI on it and you can see the needle move for every microstep...so reasonable to assume somewhere between 8um and 1um, either way plenty good enough for this sort of machine. The angular contact bearings are held in a separate part and clamped with a 5mm steel plate also cut on my router. I machined the ballscrew with an M8 thread on the end used to apply preload to the belville washers / magneto bearings.
    Z-assembled, but only with one ballnut:
Name:	DSC09384 (Medium).JPG
ID:	5876Click image for larger version.
Name:	DSC09455 (Medium).JPG
    After much deliberation I decided I couldn't get an RM1204 ballnut to fit under the lathe bed without milling some of the bed and raising it. I just milled a couple of mm off the webs in the bed to get the ballnuts to clear, so that shouldn't weaken it to much. Forgot to take a picture of that.
    Next I milled the middle protrusion off the bed stand:
Name:	DSC09418 (Medium).JPG
    Then made some 10mm spacers from ground flat stock to go between the bed stand.
    I cut the ballnut mount from 2.5" aluminium bar. Bored, drilled and tapped both ends to accommodate the ballnuts in a similar fashion to the X ballnut. Then some milling and finishing with flycutter. Next I machined the ballscrew and made a quick tube to fit over the end and transferred it into the ballnut. This enables fitting the ballnut without all the balls dropping out...
Name:	DSC09442 (Medium).JPG
    Belville washer pressure piece and one screw machined to closely fit the ballnut on the cylindrical portion. This constrains the ballnut rotationally.
Name:	DSC09450 (Medium).JPG
ID:	5883Click image for larger version.
Name:	DSC09447 (Medium).JPG
    Sliding the ballnut on:
Name:	DSC09445 (Medium).JPG
    Assembled and preloaded:
Name:	DSC09451 (Medium).JPG
ID:	5884Click image for larger version.
Name:	DSC09452 (Medium).JPG
ID:	5885Click image for larger version.
Name:	DSC09446 (Medium).JPG
    Assembled with Z-motor mount, not shown:
Name:	DSC09453 (Medium).JPG
    The 6.5kW (allegedly) brushless motor I had was the same diameter of the somewhat limited 150W DC motor this lathe came with, so it bolted straight in with the mount it came with. I just had to make a shorter shaft (so the original covers fit) and machine the pulleys. Although this motor initially seems excessive, it's arguably well matched since it has plenty of torque over the full speed range, I probably wont need to use the 1:3 ratio.
Name:	DSC09460 (Medium).JPG
ID:	5889Click image for larger version.
Name:	DSC09459 (Medium).JPG
    I've not had chance to do anything with the lathe for a couple of weeks, so I've left it like this:
Name:	DSC09461 (Medium).JPG
    I will soon add plates to the Z-motor mount to seal the belt, similar to Z.
    Now I can cut hemispheres!
Name:	DSC09470 (Medium).JPG
    Enough for now... more to follow shortly.
    *Well near enough zero backlash..
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  3. #2
    Bravo !
    Nowt like Belleville washers. After years of trying to reduce the backlash on my mill I finally did a proper job and sprung it. When you can't turn the handle at all without the slide moving, not the tiniest nudge, you will never want to go back.
    Bravo !
    Thank you... but spoke to soon I'm afraid.
    The backlash is nowhere near zero - 0.04mm on Z and 0.024mm on X. I've tried various preload settings on the Z ballnuts and different amounts of tension on the ballscrew to make sure there's no end-float. I'm therefore not sure where the backlash is coming from. The preloaded ballnut is possibly a little tight in the mount on Z, so that might be it ... I'll have to investigate. Not sure about X :(
    To do:
    Replace 80mm chuck with 100mm.
    Z-motor mount cover.
    Get 50V ESC to replace current 24V ESC so I can run up to full speed (about 3000rpm)
    Program PIC to read signal from LinuxCNC and output PWM signal for ESC
    Currently using 0-50V 20A Lab PSU with a 3000mAh LiPo battery in parallel. The battery allows the motor to be used to it's full power with an underrated PSU so long as the average power is below the rated power of the PSU. I need to buy a more permanent PSU.
    Make little 'control panel' to replace old one.
  5. #4
    Should not be possible to fail.
    Quick methodology test...
    One nut is bolted to the slide, the other nut is merely prevented from turning.
  6. #5
    Leave the chuck at 80mm, the spindle can't handle the weight of a 100m chuck.
    Ring Ketan if you don't believe me.
    John S -
  7. #6
    Yep. Although when I bored the ballnut mount on Z I didn't leave much clearance, so maybe the ballnut is skewing and binding somehow. Will have to investigate when I've got time.
    That's rather annoying, especially since I started making the backplate yesterday. Have you tried it (not that I'm disputing your experience, just wondering)?
    Looks like I need to get some external jaws for the 80mm chuck as they're missing.
  8. #7
    No not tried it, bought a C1 to play with but the little TOS got hungry and ate it.
    John S -
  9. #8
    Jonathan,
    I've been given a Myford Super 7, really don't see why folks get so excited about these things but anyway no prizes for what going to happen to it, much to the relief of my lovely little boxford who was under serious threat. So a few Q's if you don't mind.
    Did you get the Screws from Chai.? and was that the lowest pitch he does.? (I know I'm being lazy and could ask him direct but hey oh he can't answer th rest so here ya go.!!)
    Where did you get the Bellville washers.?
    What strength did you get and how many per screw.
    How did you stack them series or parallel IE: )))) or ()()
    Nice job by the way, what MAx cutting dia can you do and when do we see the video.????
  10. #9
    Did you get the Screws from Chai.? and was that the lowest pitch he does.? (I know I'm being lazy and could ask him direct but hey oh he can't answer the rest so here ya go.!!)
    As far as I know RM1204 is the smallest pitch (and diameter) he does, although I didn't ask directly. He doesn't state the ballnut dimensions, but they are a lot smaller than RM1605. RM1204: overall length=28mm, diameter=24mm,flange length=6mm, flange diameter=40mm, between flats=25mm.
    http://www.leespring.com/
    What strength did you get and how many per screw. How did you stack them series or parallel IE: )))) or ()()
    For preloading the nuts I got:
    http://www.leespring.com/uk_product_...ype=W&subType=
    For preloading the bearings I got:
    I chose the springs based on:
    Preload force=10-20% of ballscrew static load rating
    Belleville washer compressed no more than 75%
    I stacked them like () to get greater adjustment whilst maintaining the same spring constant. The Z-ballscrew has two Belleville washers at one end, the other end fixed and one angular contact bearing on each end, so the screw is tensioned. On X the end of the screw is floating, so clearly both washers and bearings at one end.
    About Ø75mm would clear the saddle, so in theory that diameter once I have found external jaws for the chuck. That reminds me I need to get/make an MT1 live centre. In practice clearly the spindle isn't strong enough to be doing that on a regular basis. I'll convert my Colchester Student lathe once this one's finished for much bigger parts.
    Video I kinda forgot...just got one rather boring shaky video but I guess I'll upload it anyway.
  11. The Following User Says Thank You to Jonathan For This Useful Post:
  12. Jonathan well done. Very well done. Have you looked at the Lathe in this video:http://www.youtube.com/watch?v=Y1IDHIcyHLY and if so when are you going to be building a tool changer? Not to egg you on but I know that something like that would be a good bit of fun for you to build.
    Michael
  1. Dyna mechtronics DM3000 lathe , mach conversion
    By dazza in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 12-12-2015, 04:35 AM
  2. Seig C4 Lathe CNC conversion
    By njhussey in forum Sieg Lathes
    Last Post: 11-04-2014, 06:40 PM
  3. FOR SALE: Axminister White Micro Lathe 2006
    By Fivetide in forum Items For Sale
    Last Post: 13-02-2013, 04:47 PM
  4. The sows ear, a Clarke Metalworker Mill / Lathe conversion to cnc
    By FatFreddie in forum Conversion Build Logs
    Last Post: 03-12-2010, 02:46 AM
  5. Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
    By No1_sonuk in forum Lead Screws, Nuts & Supports
    Last Post: 17-05-2010, 12:47 PM
